Sheet scale factor question.
One sheet for a layout in a drawing with several sheets under one model will not allow dimensions to be scaled as set in Linear Dimension, Scale factor. A dimension in the sheet, selected, shows a different factor under Properties, Primary UnitSystem, dimension scale linear. Deleting that scale number and then entering the chosen scale factor brings back the original scale factor. What should be done to set a sheet scale once for each sheet and see all resulting dimensions scaled correctly?
