SCALE command - Reference -->Points option doesn't work
Hello, the SCALE command is not working correctly. I type SCALE, specify the base point, then press R for the Reference option, and so far everything is fine. I select the reference length, and that's okay too. After that, I type 'P' for the Points option, but this mode does not work. When it was working, I could select two points to indicate the new length. I don't remember if it ever worked in Draftsight 2025 (I have tried both SP0 and the new SP1) . It definitely worked in 2024. I have already performed a clean uninstall, removing the folders from the 'Roaming' directory and cleaning the registry, but the issue remains unresolved
DRAFTSIGHT ENTERPRISE PLUS 2025 SP1
