I wonder if anyone else has encountered this problem.
I am frequently finding that if I edit the Print Configuration (from, say, portrait to landscape), DS performs the task fine, will allow you to print out correctly, but will not save the change. So when you come back to the drawing, it has reverted to its previous setting.
When things like this happen, DS often implies it is to do with legacy drawings. It is true that most of my drawings are legacy, either because I have previously created them in AC or because I have imported a drawing from others who use other software. I think that is quite an issue for DS as the problem does not exist in AC and its a serious failing if DS only plays properly with drawings it created in the first place. I have not tested to see whether this particular problem occurs even with DS created drawings - perhaps I should.
When I first used DS, everything to do with printing from the Mac version was a nightmare. It is hugely improved and is now at least workable. However, it is still pretty clunky, I am sad to say.
