Problem with layer command between 2 different Draftsight version
Hi to everybody,
I have a strange problem, I can't understand. In my computer I have installed Draftsight 2015 and I created my custom command which LOCK all layers except the one I select. Everything is working fine and I'm using this command from very long time.
Now I installed Draftsight 2016 in another computer and I import the same custom command. But, in this case, it doesn't work anymore. i tried everything, I don't know what happens, command syntax is the same.
command is the follow -LAYER;BL;*;B;; (this is in italian, it means: -LAYER;"LOCK";*;"UNLOCK";;). After some test I suspect the problem is wildcard "*": it seems that new draftsight version does not recognize this wildcard anymore.
Could you please help me?
Regards,
Michele
