I wonder if other people experience this problem?
Where lines or fills are on top of one another you can dictate which is on top or underneath. This helps ensure entities are visible.
My problem is that I often find the order you set is lost or dropped and it is difficult to see a pattern. When hatching, you can select to ensure hatching is always underneath everything. Except that it doesn't seem to work and I normally find I have to hatch first, then go back, select it, set it to go behind everything. Even then, the setting may not be maintained.
I suspect most people would want hatching to go underneath everything else by default. So perhaps that should be the default setting but left user definable for the rare occasion when you want to place it elsewhere?
I use the Mac version of DS V1R2.
