Printing - custom paper size
Before I used draftsight 2019 and everything worked well. Today I've installed premium 2022 and have issues printing a A0+-drawing. I have a drawing size 841 height by 1399mm (extra wide). This means I should use a custom paper size. I make one at 841x1399 with the printer pdf. When I try to print it it isn't good, since draftsight gives a fictive dimension of 210x297 instead of wanted size of 841x1399. This means the scale, fitting, ... isn't correct. When I use a standard A0 it doesn't give this issue. Only with custom paper size, draftsight takes 210x297. see attachments with drawing and two screenshots of problem. As said at the start, the problem wasn't there when using draftsight 2019.
thank you
