Pattern path not working
We just updated to professional to be able to use the pattern path command and it is not working (circular is working).
Though maybe draftsight was different then AutoCad i watched couple youtube videos it is the same as Autocad however it is not working. Example i draw a polyline and a standard line place a circle at the beginning and select pattern ( from the ribbon / icon bar) then pick circle than path choose equal and qty of circle and try to click preview and ok and nothing happens. If you choose it thru the Ribbon / icon it does not work, but is you use the command line it works.
