Hi.
I'm using DraftSight in order to draw schematics. Sometimes after adding several polylines with multiple 90 degree angles which connect between pins on symbols I want to make more space in a certain area of the schematic or for some reason I want to move something. I haven't found a way to select nodes in the polylines and moving only those. Instead the whole polylines are moved which means I have to move all of the nodes one by one in order for them to still stay "connected" to the pins on the symbol I didn't move. That is very time consuming.
I am using Eagle PCB for schematics for PC board and there you can select which nodes/corners and object you want to move and them move only those. It is very efficient.
Is there a simlilar select/move command for DraftSight?
Regards,
Erik
