Issue with printing by built-in printers using VBA
Hello everyone,
I'm trying execute a macro in VBA to print Model sheet, but it doesn't create PDF file in specified file path. When I change the printer to "Microsoft Print to PDF" the dialog window with printing settings appears. Does this function even work with built-in printers/plotters?
Here's my code:
Dim dsApp As DraftSight.Application
Dim dsDoc As DraftSight.Document
Dim dsSelectionManager As DraftSight.selectionManager
Dim dsPolyline As DraftSight.PolyLine
Dim dsPrintMgr As DraftSight.PrintManager
Dim dsSheet As DraftSight.Sheet
Dim sheetsArr As Variant
Dim sheetArray(0) As String
Dim printerName As String
Dim paperLength As Double
Dim paperWidth As Double
Dim top As Double
Dim bottom As Double
Dim left As Double
Dim right As Double
Dim sheetObj As Variant
Sub ConnectToDraftSight()
Debug.Print (" #### MODULE 2 - START ####")
   Set dsApp = GetObject(, "DraftSight.Application")
   If dsApp Is Nothing Then
       Set dsApp = CreateObject("DraftSight.Application")
   End If
   dsApp.Visible = True
   Set dsDoc = dsApp.GetActiveDocument
   Set dsPrintMgr = dsApp.GetPrintManager
   'Get available printers
   dsVarPrinters = dsPrintMgr.GetAvailablePrinters
   Debug.Print ("Available printers:")
   Debug.Print (" PDF")
   Debug.Print (" JPG")
   Debug.Print (" PNG")
   Debug.Print (" SVG")
   For i = 0 To UBound(dsVarPrinters)
       Debug.Print (i & ". " & dsVarPrinters(i))
   Next i
   Debug.Print (" #### USTAWIANIE DRUKARKI ####")
   'Set the printer name
   printerName = "PDF"
   dsPrintMgr.Printer = printerName
   If printerName = "" Then
       MsgBox ("Failed to set IPrintManager.Printer property " & printerName & " value.")
   End If
   'Get available paper sizes for printer
   dsVarPaperSizes = dsPrintMgr.AvailablePaperSizes
   If IsArray(dsVarPaperSizes) And UBound(dsVarPaperSizes) = 0 Then
       MsgBox ("List of available paper sizes is empty for " & dsPrintMgr.Printer & " printer.")
   Else
       Debug.Print ("Available paper sizes for " & printerName & ":")
       For i = 0 To UBound(dsVarPaperSizes)
           Debug.Print (" " & dsVarPaperSizes(i))
       Next i
   End If
   'Set paper size
   dsPrintMgr.PaperSize = "ISO_A4_(297.00_x_210.00_MM)"
   'Get paper size
   dsPrintMgr.GetPaperSize paperLength, paperWidth
   Debug.Print "Paper length: " & paperLength
   Debug.Print "Paper width: " & paperWidth
   'Get print margins
   dsPrintMgr.GetPrintMargins top, bottom, left, right
   Debug.Print ("Top margin: " & top)
   Debug.Print ("Bottom margin: " & bottom)
   Debug.Print ("Left margin: " & left)
   Debug.Print ("Right margin: " & right)
   'Set print orientation
   dsPrintMgr.Orientation = dsPrintOrientation_e.dsPrintOrientation_Landscape
   'Set the sheets to print
   sheetArray(0) = "Sheet1"
   dsPrintMgr.SetSheets (sheetArray)
   'Verify the sheets to print
   sheetObj = dsPrintMgr.GetSheets
   'If sheetObj Is Nothing Then
    '   MsgBox ("Failed to set sheets to print")
   ' End If
   'Center the printout
   dsPrintMgr.PrintOnCenter = True
   'Set print quality as defined in dsStandardPrintQuality_e
   dsPrintMgr.Quality = dsStandardPrintQuality_e.dsStandardPrintQuality_Normal
   'Scale the line weights
   dsPrintMgr.ScaleLineWeight = True
   'Scale the printout to fit the paper
   dsPrintMgr.ScaleToFit = True
   dsPrintMgr.GetAvailablePrintStyleTables dsVarPrintStyles
   Debug.Print "Available print style tables:"
   For i = 0 To UBound(dsVarPrintStyles)
       Debug.Print " " & dsVarPrintStyles(i)
   Next i
   'Set the print style table
   dsPrintMgr.StyleTable = "default.ctb"
   'Set the printing range
   dsPrintMgr.SetPrintRange dsPrintRange_e.dsPrintRange_AllGeometry, "", False, 0#, 0#, 0#, 0#
   'Use the assigned print style
   dsPrintMgr.UseAssignedPrintStyle = True
   dsPrintMgr.PrintOut 1, "c: pdf.pdf"
   MsgBox "%%%%% KONIEC %%%%"
End Sub
