Is there a way to change the default screen that pop ups appear in?
Hello, I have been a user of DraftSite 2020 for many years. I have had an issue where if I was using a second screen on the previous session (Such as the attribute block editor), that the next time I run the software it will want to re-appear in the same place regardless of where the main window is on the desktop. If I am using a second screen the next time, its fine because its still available. However, if I am on-the-go, and do not have the second screen available, it will still want to appear off to the side where I cannot use it.
This also sometimes happens if I am using a different second screen. (I have a home office, and a work office with the second screen on different sides of where I put my laptop so they are opposite of each other for the position of the "main screen" vs. the "second screen" so to fix this, I have to flip that order to get the box to appear on a screen where I can reach it.
Is there a way to configure the settings to prevent the pop up from defaulting back to the last place used in a previous session, and reset to the screen that the main window is on?
