How do I control positioning offsets in sheet layouts?
Moved from https://swym.3ds.com/#post:14762 on behalf of David Anderson this follows from his original iQuestion at https://swym.3ds.com/#community:70/iquestions:13219 .
David ANDERSON · 19 hrs ago
Thanks Ron,
that worked very nicely. Now that I do understand more about where the specific numbers go to size a viewport relative to that scale it becomes quite simple and, and very easy to manipulate.
However one more item needs to be resolved. I have been setting up some PS plots to a standard 24x36 sheet. i have the drivers for HP 750 c plotter or, the Hp/GL2 works well too.
However, it seems that there used to be a way in ACad to edit all four of the offsets relative the print and the paper size of that particular sheet.
I have looked at many of the aspects of what can be done inside the editing of the .CFG file & Print configuration dialog box. Yet I do not find an option that lets me do some final tweaking to the offsets, only the x&y instead of centering the plot. One last note, the preview looks good but my sheet tab view of the drawing (Title Block borders), does not line up with the print configuration
Can I still do a similar function with in Draftsight as well.
