Esnap doesn't work on EGrouped objects in sheet
I had used the Quick Group command to group object while working in the model. I noticed that when I try to dimension the objects in the sheet, those objects part of the EGroup don't work with Esnap. I cannot select the end point of line segments if they are part of an Egroup. Why don't the Esnaps work on grouped objects? How should I be grouping objects in the model so that I can still use Esnaps in the sheet?
