"Enable EntityGroup selection sets" command as an override key ??
I would like to know how to set or add the following command as an override key ( Ctrl+Shift+a ) :
The command would be :
which is located in the menu : Tool - Options - drafting options - entity selection - selection settings
The goal would be to enable/disable EntityGroups selection sets, to select some EntityGroup or object alone inside EntityGroups, while doing an other command, like move or rotate...
If anyone could help it could be easier and way faster doing that doing de group command and then activate/desactivate all groups... or going for that command in the menu and then doing move/rotate/etc......
THanks !!
Jean-Philippe
