Dynamic increment of Block attributes
Is there a parameter that I can use to increase the block attribute automatically when the block is inserted into the drawing space?
(as an example, if I insert valve "V1" and the once insert same symbol again attribute should be updated to "V2")
And the same time, it is possible to split drawing lines once the block is inserted into the line?
