Dynamic Block - Linear Stretch Resetting Block Table
I have the dynamic block seen and attached below. The block has two different visibility elements, a block table, and a linear stretch action. The block table determines the attribute values for the three charts seen in the attachment. The linear stretch allows the user to extend the point based on their need. The problem is, if you choose your desired visibility states first and then use the linear stretch grip, it will reset the block table values to their default value. Is there anyway to prevent the linear stretch from resetting the block attribute values that are defined in the block table? If you stretch first and then select your visiblity states it works as expected.
