dsApp.NewDocument("standarddin.dwt") problem
I have created a small macro to generate DXF files based on data transferred from Excel. However, I encountered an issue with the dsApp.NewDocument("standarddin.dwt") function, which behaves inconsistently. Sometimes it works fine, but other times it creates a new drawing, and the events confirm its creation, yet Excel reports an issue. After pressing "Continue," the file gets created again, but DraftSight is unable to properly work with the previously generated file. And any action with that file can crash the draftsight. Here is my code, could you please help with problem I faced?:
Function DrawRectangleWithLinesDs(ByRef dsApp As DraftSight.Application, savePath As String)
   Dim ws, ws1 As Worksheet
   Dim doc As DraftSight.Document
   Dim doc2 As DraftSight.Document
   Dim modelSpace As DraftSight.Model
   Dim dsSketchMgr As DraftSight.SketchManager
   Dim ObjColor As DraftSight.color
   Dim objRect As DraftSight.polyline
   Dim pts(0 To 9) As Double
   Dim textObj As DraftSight.SimpleNote
   Dim insertPoint(0 To 2) As Double
   ' avoid nested commands
   dsApp.AbortRunningCommand
   'Set up events
   Set dsAppEvents = New Class1
   Set dsDocEvents = New Class2
   Set dsAppEvents.app = dsApp
   Set doc = dsApp.GetActiveDocument()
   FileNewNotify = False
   Set ws = ThisWorkbook.Sheets("PART LIST")
   Set ws1 = ThisWorkbook.Sheets("PART LIST OUT")
   Dim j As Integer
   For j = 11 To ws.Cells(ws.Rows.count, 2).End(xlUp).Row
       ' Get Data
       Dim TrBreath As Double, TrHeight As Double, TrLength As Double, TrRadius As Double
       Dim TrMaterial As String, TrSection As String, TrYardNumber As String
       Dim TrThickness As Double, TrNumber As String, TrQuantity As String, TrRevision As String
       If InStr(1, ws.Cells(j, 6).Value, "BENT PLATE", vbTextCompare) > 0 And ws.Cells(j, 2).Value <> ws.Cells(j - 1, 2).Value Then
           a = Split(ws.Cells(j, 6), " ", -1)
           TrRadius = a(4)
           a = Split(a(2), "x", -1)
           TrBreath = a(0)
           TrHeight = a(1)
           TrLength = ws.Cells(j, 10).Value
           TrThickness = ws.Cells(j, 12).Value
           TrMaterial = ws.Cells(j, 7).Value
           TrSection = ws.Cells(4, 5).Value
           TrYardNumber = ws.Cells(4, 4).Value
           TrNumber = ws.Cells(j, 2).Value
           TrRevision = ws.Cells(j, 5).Value
           For i = 18 To ws1.Cells(ws1.Rows.count, 2).End(xlUp).Row
           If ws.Cells(j, 2).Value = ws1.Cells(i, 2).Value Then TrQuantity = ws1.Cells(i, 3).Value
           Next i
           Application.Wait Now + TimeValue("00:00:02")
           Do While FileNewNotify = False
           Set doc2 = dsApp.NewDocument("standarddin.dwt")
           DoEvents
           Loop
           If doc2 Is Nothing Then
               MsgBox ("Failed to create a new document in DraftSight.")
               Exit Function
           End If
           Set dsDocEvents.doc = doc2
           Set modelSpace = doc2.GetModel()
           Set dsSketchMgr = modelSpace.GetSketchManager()
           ' Points calculation (0,0)
           pts(0) = 0
           pts(1) = 0
           pts(2) = 2 * TrHeight + TrBreath - 4 * TrRadius + pi * (TrRadius + TrThickness / 2)
           pts(3) = 0
           pts(4) = 2 * TrHeight + TrBreath - 4 * TrRadius + pi * (TrRadius + TrThickness / 2)
           pts(5) = TrLength
           pts(6) = 0
           pts(7) = TrLength
           pts(8) = 0
           pts(9) = 0
           Set objRect = dsSketchMgr.InsertPolyline2D(pts, True)
           doc2.Rebuild (dsRebuildType_AllViewports)
           Set ObjColor = objRect.color
           ObjColor.SetColorByIndex (3)
           objRect.color = ObjColor
           objRect.Layer = "0"
           Dim line1(0 To 3) As Double
           Dim line2(0 To 3) As Double
           line1(0) = TrHeight - TrRadius + pi * (TrRadius + TrThickness / 2) / 4
           line1(1) = 0
           line1(2) = TrHeight - TrRadius + pi * (TrRadius + TrThickness / 2) / 4
           line1(3) = TrLength
           line2(0) = TrHeight + TrBreath - 3 * TrRadius + 3 * pi * (TrRadius + TrThickness / 2) / 4
           line2(1) = 0
           line2(2) = TrHeight + TrBreath - 3 * TrRadius + 3 * pi * (TrRadius + TrThickness / 2) / 4
           line2(3) = TrLength
           ObjColor.SetColorByIndex (4)
           Set objRect = dsSketchMgr.InsertPolyline2D(line1, False)
           objRect.Layer = "0"
           insertPoint(0) = TrHeight - TrRadius + pi * (TrRadius + TrThickness / 2) / 4
           insertPoint(1) = TrLength / 4
           insertPoint(2) = 0
           ObjColor.SetColorByIndex (7)
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 10, pi / 2, "TSKN R=" & TrRadius & " DEG=90")
           textObj.color = ObjColor
           textObj.Layer = "0"
           Set objRect = dsSketchMgr.InsertPolyline2D(line2, False)
           objRect.Layer = "0"
           insertPoint(0) = TrHeight + TrBreath - 3 * TrRadius + 3 * pi * (TrRadius + TrThickness / 2) / 4
           insertPoint(2) = 0
           textObj.Layer = "0"
           insertPoint(0) = TrHeight + 50
           insertPoint(1) = TrLength - 20
           insertPoint(2) = 0
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 10, 0, TrSection)
           textObj.Layer = "0"
           insertPoint(1) = TrLength - 40
           insertPoint(2) = 0
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 10, 0, TrNumber)
           textObj.Layer = "0"
           insertPoint(0) = 0
           insertPoint(1) = 0
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[P]" & TrNumber)
           textObj.Layer = "0"
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[T]" & TrThickness)
           textObj.Layer = "0"
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[I]" & "Bent Plate")
           textObj.Layer = "0"
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[B]" & TrYardNumber)
           textObj.Layer = "0"
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[N]" & TrSection)
           textObj.Layer = "0"
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[M]" & TrMaterial)
           textObj.Layer = "0"
           Set textObj = dsSketchMgr.InsertSimpleNote(insertPoint(0), insertPoint(1), insertPoint(2), 5, 0, "[Q]" & TrQuantity)
           textObj.Layer = "0"
           Dim dsTextStyleManager As DraftSight.TextStyleManager
           Set dsTextStyleManager = doc2.GetTextStyleManager()
           Dim dsTextStyle As DraftSight.TextStyle
           Set dsTextStyle = dsTextStyleManager.GetTextStyle("Standard")
           dsTextStyle.Font = "txt.shx"
           Set dsTextStyle = Nothing
           Set dsTextStyleManager = Nothing
           Set textObj = Nothing
           Set objRect = Nothing
           Set ObjColor = Nothing
           Set dsSketchMgr = Nothing
           Set modelSpace = Nothing
           TrMaterial = Trim(Replace(Replace(Replace(TrMaterial, "[M]", "", 1), "Steel", "", 1), "Grade", "", 1))
           doc2.SaveAs2 savePath & TrYardNumber & "_" & TrSection & "_" & TrNumber & "_" & TrMaterial & "_" & TrThickness & "_Rev_" & TrRevision & ".dxf", dsDocumentSaveAs_R2000_R2002_ASCII_DXF, True, dsDocumentSave_Succeeded
           PathName = doc2.GetPathName
           dsApp.CloseDocument PathName, False
           Do While docDestroyNotify = False
           DoEvents
           Loop
           Set doc2 = Nothing
       End If
   Next j
End Function
