Draftsight Printer drivers
Again, I am wondering if there are certain drivers that are pre installed or, that are recommended for Draftsight.
I would suspect that would be similar to what has been used and done with a AutoCad .plt files in order to properly set the Print Configuration Manager to a certain set of parameters.
The help guide is not rel specific here & I have spen a great deal of time trying to research this.
When I was operating with AutoCAD there were certain Hewlett Packard Hedi drivers for a plotter like the  HP 750 color plotter that I could use to set a plot file.
What i mean is that the printer drivers also help when doing a initial sheet set up in the sheet tab mode or, as it is known in the cad community as paper space configuration manager, there does not seem an option to set the paper or sheet offsets.As an standard sheet example for a 24x36 landscape print file:  1.15 inches for where it would be bound or the left side, then the other sides typically set to be a 1/2 margin. Just not sure what can be done in order to set these up any with drawing or, a plot file.
Also, I was told to go to the Draftsight community but, it seems rather difficult in order to find out where & how to post.
I wish someone would makes this more user friendly.
David
