Draftsight (Free) Edit block in place is broken after hotfix
Hello, I was running Draftsight 2016 on my windows 10 machine just fine until the hotfix came along. Now I cannot edit blocks in place. I get the message "Cannot edit-in-place some entities from this component". I tried exploding the block and then making a new block which it does do but then when I try and edit the block it throws up the same error message. My block only consists of 11 lines and two arcs and saved as a R2010 dwg file. Finally this morning I removed Draftsight 2016 and downloaded Draftsight 2017 SP1. Same darn problem. To get anything done, I have to use AutoCAD at work or DoubleCAD at home to edit the blocks. A simple drawing with one of the blocks is attached (hopefully). How do I fix this?
Thanks, Bill
Edit, well I guess we cannot attach dwg files, it seems to just convert them to an image...
