Has anybody noticed an issue with printing more than one drawing in a row with both the current (V1R4) and previous (V1R3.2) versions of Draftsight.
For example, say you have a multi-sheet drawing in model space, call up an A3 print configuraton and print the first sheet of the drawing, this will be printed at the desired size of A3, but subsequent plots will default to printing at A4 - despite the fact that the dialogue box is showing the paper sizes as A3.
Currently the workaround seems to be changing the paper size to anything else and then back to A3 before printing the next sheet(s) - you then get the correct plot size.
This problem also seems to effect the use previous settings option.
The first plot always comes out the correct size.
Machine Spec:
Window 7 Pro (64 Bit), Dell Precision T3400, Intel Core2 Duo Processor (E7300 @ 2.66 GHz), 4GB Ram, NVIDA Quadro FX 570 graphics card.
