Draftsight command syntax in script files
Hi.
I have converted a large PDF to a lot of dxf files.
I now have hundreds of files to bring into a single DWG file
I only want to select the same area in each file and do a copy with reference point.
when using the SCR file I can draw lines etc. But I can not get the select command to select several areas and then process the next command.
in the command window it is sitting at select: and waiting for further input.
Is there a command reference document for the script syntax for commands?
The HELP says open command history and copy it
Specify entities»
: ._MAINSELECTSpecify opposite corner:
: ._MAINSELECT
: _COPY@
Specify reference point»
3 found, 48 total
: COMMANDHISTORY
copy and pasting this to a text document does not produce a working script file
THX
