DraftSight Batch Print – File Name Sorting & Output Order Issue
I’m facing an issue with Batch Print in DraftSight SP3 2025:
  • The "File name (Sheet name)" column does not allow proper sorting of files by their names, like it used to do in 2024 versions.
  • Even if I manually arrange/reorder the files in that column, the generated PDF files are always printed in the default numbering order, not in the order I set.
This is causing problems when trying to maintain drawing order in combined PDF outputs.
Has anyone else run into this issue? Is there a workaround or a setting I might be missing?
Thanks in advance.
