We just upgrading to the latest version of DraftSight Professional (2015 x64). Up until this version, I have had no printing issues. With the latest version, drawings look perfect in the DraftSight Print Preview, but they come out of the printer cut off on the bottom & the right hand side.
We use a Ricoh Multifunction printer, model MP C3003, with a PCL 6 64-bit driver for Windows 7 Professional. This machine is a full size, commercial-duty copier/scanner/printer/fax machine & was used for our previous DraftSight versions with no issues whatsoever.
We use only model space for our drawings; we draw 1:1, then insert our drawing border as a block. The block is then exploded & scaled to an appropriate size to fit the model. We then set the dimension fit to match the border's scale.
Up until now, all I did to print from DraftSight was to pick the Ricoh printer, choose a paper size (8.5x11 or 11x17), choose landscape or portrait, choose a print scale or pick "Fit to paper size", pick "Print on center of paper", then pick "Specify Window" & window the drawing print area I want, check the "Print Preview", the click "Print". Perfect prints every time.
Now when I print this way, the prints are cut off. It doesn't matter what printing options I choose, whether plotting to scale or scaled to fit, whether or not I specify a window, whether or not if I choose plot centering or if I choose "Print inverse" or not.
I've tried printing from Paper Space, but the same thing happens...cut off on the right & bottom of the sheet.
I've tried switching to older PCL Ricoh printer drivers & I've tried using Postscript drivers, too. Same results.
No other programs we use, such as Word, Excel, Outlook, etc. have any printing issues.
When I print a DraftSight drawing as a PDF, it's perfect.
I'm pretty sure the problem is exclusive to the new DraftSight version. What could be wrong? How do I fix it?
Help!
