Draftsight 2015 Installed but will not run. Loads up then error message
Dear Sir/Madam
First  off thank you for making this excellent package free for users.
My problem is, I had an older version of Draftsight which worked perfectly
apart from when I tried to insert an image, I wanted to insert a 3 view drawing
of an aircraft trace around it and make it into a flying model aircraft. Unfortunately
the image would not display. So I looked on the net and other people were having
the same problem. So I thought an upgrade to the 2015 version might cure the problem.
Alas the 2015 won't even run, it installed and loaded Draftsight then an error appeared
and said something about it could not find a certain folder and then it shut it's self down.
I kept and sent the error report, I also emailed the crash report zip file to the crash report email address.
Can anyone help please as I was just about to draw up my first two model aircraft,
if anyone is interested they are a Fokker eindecker and a Focke Wulf 190D
I really do like this package when it works, with all the help and support with the videos
and webinares etc. It really is first class. I am 60 and can use it, so if I can anyone can.
Thank you.
Regards Phil Goff
