Draftsight 1V2.x issue with opening dwg files saved in autocad 2004-2006
Hello. I have found a problem trying to open several files originally saved on Autocad, probably on 2004, 2005 or 2006 version (in dwg file header there is "AC1018" entry). I originally am working on Autocad 2000 so I treat DraftSight as very good converter, better than DWGTrueView. When user tries to open these problematic dwg files under 1V2.x and when progress bar reaches 50-70% DraftSight informs that dwg file needs to be recovered. If I choose "Cancel" the opening procedure stops, and when I choose "OK" DraftSight will start recoverying procedure but when 50-70% is reached it drops it and opens new empty Noname.dwg file.
These problematic dwg files are opening like a charm on Autocad 2006 and higher, DWGTrueView and DraftSight 1V1.4. Version 1V1.4 opens them without any error message or recoverying procedure.
