Win 7 Pro x64, 4Gb Ram
Intel Q45\\43 Graphics card
I have attempted a clean \\uninstall \\ reinstall
By this I mean:
uninstalled, removed the roaming directory(for Draft Sight), program data directory (for Draft Sight) and the program files directory (for Draft Sight). Removed the registry entries.
[-HKEY_CURRENT_USER\\Software\\Dassault Systemes]
[-HKEY_CURRENT_USER\\Software\\Dassault Systemes\\DraftSight]
[-HKEY_CURRENT_USER\\Software\\SWActivation]
[-HKEY_CURRENT_USER\\Software\\SWActivation\\K2]
Performed a registry cleaning.
Logged in as a local Admin acount and re-installed (attempted both as elevated "Run As administrator" and just simply double clicking the installer. Neither installation method after clean uninstall resolves the issue.
Event Logs shows:
Faulting application name: draftsight.exe,
version: 17.1.0.12557,
time stamp: 0x58ac068d
Faulting module name: draftsight.exe,
Exception code: 0xc0000005
Fault offset: 0x000000000002adb7
Faulting process id: 0x1720
Faulting application start time: 0x01d2bad39c28924d
Faulting application path: C:\\Program Files\\Dassault Systemes\\DraftSight\\bin\\draftsight.exe
Faulting module path: C:\\Program Files\\Dassault Systemes\\DraftSight\\bin\\draftsight.exe
Report Id: e010a424-26c6-11e7-8d70-b8ac6f9e00ae
Antii-virus has been disabled during install\\uninstall, MS Security essentials is also disabled, Windows defender has been disabled. (note I have tried with and without win defender disabled)
I have changed the graphics properties to most updated driver, and set all 3d options to best performance or application specific.
Nothing seems to be working, what am I missing here?
Thank You,
