Feature works good for dimensions with text size 2mm ie if you are drawing one to one or in paper space but if I am drawing in the model space and viewport is one to 50 (for example) the offset distance stay the same and do not scale up. I thought maybe changing the annotations scale would sort it but no difference.
so are you meant to go into options to change the dim offset value every time I change the dim style I assume there is a better way?
thanks for the help in advance
