We are seeing a consistent issue with DraftSight crashing when using the Rotate command.
We open an existing file that is saved in a network folder. We type Rotate or select Rotate from the menu. We select the entities we want to rotate. We click to select the rotation point. DraftSight crashes every time at this point. The crash happens regardless of the part file being used.
The only solution we have found for this is to revert back to a prior version of Draftsight.
