In the last few days my Draftsight 2021 SP0 has starting defaulting the results of the copy and define block functions to the active layer, rather than the preserving the existing layer settings. If I select the active layer option when copying and set it to no, it still goes ahead and copies everything to the active layer. Is there a setting somewhere to fix this behaviour? I have tried the usual fix of resetting Draftsight AppData and I even reverted back to 2020 SP4 but the problem remained. Using Ctrl+C still works as required.
Thanks
: _COPY
Active settings: Copy on active layer = Off
51 found
Default: active Layer
Options: Displacement, active Layer or
Specify from point» _Layer
Default: No
Options: Yes, No or
Assign to active layer?» _No
Specify from point»
Options: Pattern, Enter to use first point as displacement or
Specify second point»
Default: Pattern
Options: Pattern, Exit, Undo or
Specify second point» «Cancel»
