Does anyone know if there is a way to create complex command aliases. For
example:
?command="_-VIEWS _ORTHOGRAPHIC _BOTTOM " alias="vbot"
If this is put into the aliases.xml file and then you try and use the command you get:
: vbot
Unrecognized command _-VIEWS _ORTHOGRAPHIC _BOTTOM. Press F1 for help.
it actually does work to put this sort of thing in the application.xml file but it seems that
you can only assign it to a hotkey, menu item or toobar button.
