Command Stack Depth
2020 SP2 Pro - anyone run into a "Exceeded maximum command stack depth" error? Once encountered, the only solution I've found is to exit via the Task Manager and restart DraftSight. Comes after command seems get "stuck" (property painter, in my case) and can't be cancelled or interrupted. The ":" normally at the beginning of a fresh command is missing, as if I activated a command within a command - which I have not willing done so.
