Hi
I have Dynamically adding user commands to insert block , because have more than 100 blocks.
string commandString = "^C^C-INSERTBLOCK;C:\\\\temp\\\\2COV22.dwg;\\\\1;1;0;;";
UserCommand lineUserCmd = mPlugin.dsApplication.CreateUserCommand(blockName, "Execute line command", commandString, "BLOCK", string.Empty, string.Empty, dsUIState_e.dsUIState_Document, out error);
ContextMenuItem dsDefaultContextMenuItem = mPlugin.dsApplication.AddDefaultContextMenu(blockName, menuItemType, blockName, lineUserCmd.GetID());
above code is running when user selecting block in my own Addin panel
now it is executing when Right-click anywhere in the the graphics area and select Execute line command in the context-sensitive menu.
I wanted to execute macro command in one click when select block..
is there a way to execute macro command dynamically ..
Fathima
