I have found seriously memory leak in Draftsight (I don't know it is good place to post about development issues).
[Bug report]
Version: V1R3, V1R2.3
OS: GNU/Linux, Microsoft Windows;
Component: Sheet switch
Severity: Major
Description:
When you switch between sheets memory isn't released.. It is annoying when you have big sheet and 200MB memory leak per one switch.
Reproduce:
Just switch between two sheets many times and measure memory use or test it using profiler such as valgrind (only GNU/Linux). It can be seen that the memory level tends to infinity or yours physical memory limit.
Sincerely,
Zbigniew Rebacz
