I'm getting DraftSight setup on my PC running Windows 7 x64. I've installed DraftSight V1R3.1 and I have a question about inserting blocks using the command line.
I'm eventually working toward getting a custom menu setup with commonly used blocks. Currently, I have a blocks folder setup on a network drive at X:\\Blocks. I've also setup the "Library Files Location" to X:\\Blocks.
So for example, I want to insert a block called "widget" stored at X:\\Blocks\\widget.dwg. If I use the -insert command, it will ask for a block name as expected. If I type in widget or *widget.dwg, I'll get a message saying "Cannot find the specified drawing file. Verify that the file exists". However, if I go -insert and then type X:\\Blocks\\widget.dwg when it asks for the name, then the block is inserted just fine.
Is this the expected behavior? My understanding with the blocks library is that I don't have to specify the fully path of the block - just the name will do. Normally I wouldn't worry about it, but since I want to build a custom menu for inserting these blocks, I don't want to specify the full path of the blocks folder gets mapped to a different drive letter, for example.
Any insight or advise is much appreciated.
Thanks,
Francis
