Batch plot not working well since upgrade to DS2019
I was using Batch Print with my DraftSight 2018 without any problem. I was using the ACTIVED ploter configuration and everything was fine. Since I've upgraded to DS2019, each time I'm trying to batch print it doesn't select the default MODEL to plot with the ACTIVATED plot configuration so I have to manual select which document, which view and the plot configuration for each document.
Here's the way I'm able to get it back to work normaly:
1) Open one file
2) Open that PloterConfigurationManager and ACTIVATE the correct Plot Config
3) Plot that single FILE
4) While leaving DS opened, I invoke the Batch Plot ... add files and NOW bam it works like it was before ... selecting all my MODEL views and using the ACTIVED plot configuration.
As soon as I close DS and reopen it I loses all memory of that ACTIVATED profile and I have to do the same procedure again ... so maybe it's linked with a Registry or Folder Security like other bugs buth now I'm stuck and I need help to get back my working batch plot solution (that is the only reason why I'm paying for the Pro version)
Thank you
