hi,
after installing the latest version 2019.1.0.2154 or 2019.2.0.3115, I have DraftSight in 640x480 resolution. can i give Printscreen. Icons like a horse and can't work: ((
- using Linux Mint (Ubuntu)
- in /home/name_user/.config/DraftSight/2019.1.0.2154/Profiles I found a few references to resolution
- in /tmp/DraftSight__temp/gl_info.txt I found some log where the sentence is:
Display monitors count - 2
Primary display monitor resolution - 640x360
- Please help. It is not possible to work with this resolution and the 1920x1080 monitor. Not only that you can't see part of the window, but you can't move it. If I change the resolution to OS 640x480 it is smiley to try to do something.
- if I throw an older version there so it does not go because it expired but has a resolution ok.
- Importing your old profile didn't help
thanks
