AutoCAD script (.scr) file not working in DraftSIght, will not find printer
Our company is moving away from AutoCAD and opting to use DraftSIght 2017.  There is a script file (*.scr) that ran fine in AutoCAD that one of my users is having trouble with in DS.
The script *will* run in DS but it gives an error when it comes to printing the drawings (as noted in section I marked with *** ****) and stops.  It never prints out the sheets that are generated by the script.  You can manually print the sheets but there are several scripts that have to run in succession so the flow stops once it reaches end of first script.
Suggestions?  Ideas?  What am I missing?  I think this is a syntax issue but could use some guidance.  Thanks everyone.
Cynthia
: '_LOADSCRIPT
: text
SIMPLENOTE
Active TextStyle: "Standard" Text height: 2.0000 Annotative: No
Options: Justify, textSTyle or Specify start position» -55,40
Default: 2.0000 Specify height» 2
Default: 0 Specify text angle» 0
Specify text» 206843
: text
SIMPLENOTE
Options: Justify, textSTyle or Specify start position» -55,37
Specify text» 2 0 H21131C
: layer
Options: ? to list, Freeze, LColor, LOck, LStyle, LWeight, TRansparency, Make, MATerial, New, Printable, Thaw, stAte or Unlock Specify option» _ON
Specify layer(s)» T64-1072-100
: LAYER
: layer
Specify layer(s)» T97-1023-212
: LAYER
: layer
Specify layer(s)» R256-644-3L2
: LAYER
: layer
Specify layer(s)» R294-324-9
: LAYER
: plot
PRINT
Default: No Confirm: Advanced print options? Specify Yes or N _Yes
Default: Model Options: ? to list or Specify sheet name» model \\\\tn1print01\\TN1-Syteline-07
not found.   ***This appears to be where the problem starts ***
Default: Model Options: ? to list or Specify sheet name» Letter
not found.
Default: Model Options: ? to list or Specify sheet name» Inches
not found.
Default: Model Options: ? to list or Specify sheet name» Landscape
not found.
Default: Model Options: ? to list or Specify sheet name» No
not found.
Default: Model Options: ? to list or Specify sheet name» Extents
not found.
Default: Model Options: ? to list or Specify sheet name» Fit
not found.
Default: Model Options: ? to list or Specify sheet name» 0.00,0.00
not found.
not found.
Default: None Options: ? to list or Specify printer name» Yes
 not found.
Cannot use None device for printing.
The printer name is noted in the script but for some reason it will not find the printer.  The name is correct and nothing on the printer side has changed.
