Attribute captions do not match attribute properties
I am using DraftSight 2017 x64 sp1.  When I insert a block with attributes, the dialog box for entering the attribute values appears as normal.  The problem I am having is that many of the attribute captions that appear in this dialog box do not match the caption that is in the attribute properties.  As a matter of fact, many of the attributes in the dialog box show up with the same caption, when in actuality the captions for each attribute in the block are unique.  (The reason I know this is that I have checked the attribute properties in 'Block Edit' mode.)  Also, I do not recall having this issue with earlier versions of DraftSight.  Any help with this will be greatly appreciated.
