Annotative Text Becomes Smaller After Input
I'm experiencing an issue with annotative text in DraftSight 2025 SP1.
When I input text using an annotative text style (NOTE), it appears at the correct size while editing. However, once I finish the input, the text becomes significantly smaller.
Current setup:
  • Model Space
  • Annotation scale: 1:20
  • Text style (NOTE) is annotative
  • Annotation scale is correctly assigned to the text object
Additional details:
  • In the STYLE command, the text height is set to 3
  • However, after placing the text, selecting the annotation shows the paper text height as 0.15
  • This issue only started recently; it was working correctly until yesterday with the same workflow
It seems like the annotation scale is applied, but the final paper height is not behaving as expected.
Has anyone experienced a similar issue or knows what might be causing this?
