Add details to table
Good day community,
    This code is from Lee Mac, based on what it's supposed to do this is exactly what I need. However, when I used it, it doesn't place the blocks to the table or any details for that matter. Do I need to change something on my block's properties or to the code? thank you in advance.
 ;;--------------=={ Count.lsp - Advanced Block Counter }==--------------;;
;;  This program enables the user to record the quantities of a         ;;
;;  selection or all standard or dynamic blocks in the working drawing. ;;
;;  The results of the block count may be displayed at the AutoCAD      ;;
;;  command-line, written to a Text or CSV file, or displayed in an     ;;
;;  AutoCAD Table, where available.                                     ;;
;;  Upon issuing the command syntax 'count' at the AutoCAD              ;;
;;  command-line, the user is prompted to make a selection of standard  ;;
;;  or dynamic blocks to be counted by the program. At this prompt,     ;;
;;  the user may right-click or press 'Enter' to automatically count    ;;
;;  all blocks in the drawing.                                          ;;
;;  Depending on the output setting, the results may then be printed    ;;
;;  to the AutoCAD command-line and displayed in the Text Window, or    ;;
;;  the user will be prompted to specify an insertion point for the     ;;
;;  table, or a filename & location for the Text or CSV output file.    ;;
;;  The program settings may be configured using the 'countsettings'    ;;
;;  command; this command will present the user with a dialog interface ;;
;;  through which the data output, table & file headings, displayed     ;;
;;  columns, sorting field & sort order may each be altered.            ;;
;;  Author:  Lee Mac, Copyright © 2014  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2010-06-05                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2010-06-06                                      ;;
;;  - Updated code to include Settings dialog.                          ;;
;;  - Added Undo Marks.                                                 ;;
;;  Version 1.2    -    2010-06-06                                      ;;
;;  - Fixed bug with 64-bit systems.                                    ;;
;;  Version 1.3    -    2011-03-02                                      ;;
;;  - Program completely rewritten.                                     ;;
;;  - Updated code to work without error on 64-bit systems by fixing    ;;
;;    bug with ObjectID subfunction - my thanks go to member 'Jeff M'   ;;
;;    at theSwamp.org forums for helping me solve this problem.         ;;
;;  - Added ability to write block count to Text/CSV Files.             ;;
;;  Version 1.4    -    2014-06-15                                      ;;
;;  Version 1.5    -    2015-06-07                                      ;;
;;  - Minor update to enable full compatibility with ZWCAD.             ;;
;;    (regeneratetablesuppressed property not available)                ;;
(setq
   count:version "1-5"
   count:defaults
       (out "tab")
       (tg1 "1")
       (tg2 "1")
       (tg3 "1")
       (ed1 "Block Data")
       (ed2 "Preview")
       (ed3 "Block Name")
       (ed4 "Count")
       (srt "blk")
       (ord "asc")
(defun count:fixdir ( dir )
   (vl-string-right-trim "\\\\" (vl-string-translate "/" "\\\\" dir))
(defun count:getsavepath ( / tmp )
   (cond
       (   (setq tmp (getvar 'roamablerootprefix))
           (strcat (count:fixdir tmp) "\\\\Support")
       (   (setq tmp (findfile "acad.pat"))
           (count:fixdir (vl-filename-directory tmp))
       (   (count:fixdir (vl-filename-directory (vl-filename-mktemp))))
(setq count:savepath (count:getsavepath) ;; Save path for DCL & Config files
     count:dclfname (strcat count:savepath "\\\\LMAC_count_V" count:version ".dcl")
     count:cfgfname (strcat count:savepath "\\\\LMAC_count_V" count:version ".cfg")
(defun c:blkcount
       *error*
       all
       col
       des dir
       ed1 ed2 ed3 ed4
       fil fnm fun
       hgt
       idx ins
       lst
       ord out
       row
       sel srt
       tab tg1 tg2 tg3 tmp
       xrf
   (defun *error* ( msg )
       (if (= 'file (type des))
           (close des)
       (if (and (= 'vla-object (type tab))
                (null (vlax-erased-p tab))
                (= "AcDbTable" (vla-get-objectname tab))
                (vlax-write-enabled-p tab)
                (vlax-property-available-p tab 'regeneratetablesuppressed t)
           (vla-put-regeneratetablesuppressed tab :vlax-false)
       (if (and (= 'vla-object (type count:wshobject))
                (not (vlax-object-released-p count:wshobject))
           (progn
               (vlax-release-object count:wshobject)
               (setq count:wshobject nil)
       (count:endundo (count:acdoc))
       (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
           (princ (strcat "\\nError: " msg))
       (princ)
   (if (not (findfile count:cfgfname))
       (count:writecfg count:cfgfname (mapcar 'cadr count:defaults))
   (count:readcfg count:cfgfname (mapcar 'car count:defaults))
   (foreach sym count:defaults
       (if (not (boundp (car sym))) (apply 'set sym))
   (if (and (= "tab" out) (not (vlax-method-applicable-p (vla-get-modelspace (count:acdoc)) 'addtable)))
       (setq out "txt")
   (count:startundo (count:acdoc))
   (while (setq tmp (tblnext "block" (null tmp)))
       (if (= 4 (logand 4 (cdr (assoc 70 tmp))))
           (setq xrf (vl-list* "," (cdr (assoc 2 tmp)) xrf))
   (if xrf
       (setq fil  (list '(0 . "INSERT") '(-4 . "")))
       (setq fil '((0 . "INSERT")))
   (cond
       (   (null (setq all (ssget "_X" fil)))
           (count:popup
               "No Blocks Found" 64
               (princ "No blocks were found in the active drawing.")
       (   (and (= "tab" out) (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer)))))))
           (count:popup
               "Current Layer Locked" 64
               (princ "Please unlock the current layer before using this program.")
       (   (progn
               (setvar 'nomutt 1)
               (princ "\\nSelect blocks to count : ")
               (setq sel
                   (cond
                       (   (null (setq sel (vl-catch-all-apply 'ssget (list fil))))
                           all
                       (   (null (vl-catch-all-error-p sel))
                           sel
               (setvar 'nomutt 0)
               (null sel)
       (   (or (= "com" out)
               (and (=  "tab" out) (setq ins (getpoint "\\nSpecify point for table: ")))
               (and (/= "tab" out)
                   (setq fnm
                       (getfiled "Create Output File"
                           (cond
                               (   (and (setq dir (getenv "LMac\\\\countdir"))
                                        (vl-file-directory-p (setq dir (count:fixdir dir)))
                                   (strcat dir "\\\\")
                               (   (getvar 'dwgprefix))
                           out 1
           (repeat (setq idx (sslength sel))
               (setq lst (count:assoc++ (count:effectivename (ssname sel (setq idx (1- idx)))) lst))
           (if (= "blk" srt)
               (setq fun (eval (list 'lambda '( a b ) (list (if (= "asc" ord) '< '>) '(strcase (car a)) '(strcase (car b))))))
               (setq fun (eval (list 'lambda '( a b ) (list (if (= "asc" ord) '< '>) '(cdr a) '(cdr b)))))
           (setq lst (vl-sort lst 'fun))
           (cond
               (   (= "com" out)
                   (defun prinn ( x ) (princ "\\n") (princ x))
                   (prinn (count:padbetween "" "" "=" 60))
                   (if (= "1" tg1)
                       (progn
                           (prinn ed1)
                           (prinn (count:padbetween "" "" "-" 60))
                   (prinn (count:padbetween ed3 ed4 " " 55))
                   (if (= "1" tg3)
                       (foreach itm lst
                           (prinn (count:padbetween (car itm) (itoa (cdr itm)) "." 55))
                       (foreach itm lst (prinn (car itm)))
                   (textpage)
               (   (= "tab" out)
                   (if (= "1" tg3)
                       (setq lst (mapcar '(lambda ( x ) (list (car x) (itoa (cdr x)))) lst))
                       (setq lst (mapcar '(lambda ( x ) (list (car x))) lst))
                   (setq hgt
                       (vla-gettextheight
                           (vla-item
                               (vla-item (vla-get-dictionaries (count:acdoc)) "acad_tablestyle")
                               (getvar 'ctablestyle)
                           acdatarow
                   (setq tab
                       (vla-addtable
                           (vlax-get-property (count:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
                           (vlax-3D-point (trans ins 1 0))
                           (+ (length lst) 2)
                           (+ 1 (atoi tg2) (atoi tg3))
                           (* 2.5 hgt)
                           (* hgt
                               (max
                                   (apply 'max
                                       (mapcar 'strlen
                                           (append
                                               (if (= "1" tg2) (list ed2))
                                               (if (= "1" tg3) (list ed4))
                                               (cons ed3 (apply 'append lst))
                                   (if (= "1" tg1) (/ (strlen ed1) (+ 1 (atoi tg2) (atoi tg3))) 0)
                   (if (vlax-property-available-p tab 'regeneratetablesuppressed t)
                       (vla-put-regeneratetablesuppressed tab :vlax-true)
                   (vla-put-stylename tab (getvar 'ctablestyle))
                   (setq col 0)
                   (mapcar
                      '(lambda ( a b ) (if (= "1" a) (progn (vla-settext tab 1 col b) (setq col (1+ col)))))
                       (list tg2 "1" tg3)
                       (list ed2 ed3 ed4)
                   (setq row 2)
                   (foreach itm lst
                       (if (= "1" tg2)
                           (count:setblocktablerecord tab row (setq col 0) (car itm))
                           (setq col -1)
                       (foreach txt itm
                           (vla-settext tab row (setq col (1+ col)) txt)
                       (setq row (1+ row))
                   (if (= "1" tg1)
                       (vla-settext tab 0 0 ed1)
                       (vla-deleterows tab 0 1)
               (   (setenv "LMac\\\\countdir" (count:fixdir (vl-filename-directory fnm)))
                   (if
                           (if (= "txt" out)
                               count:writetxt
                               count:writecsv
                           (append
                               (if (= "1" tg1)
                                   (list (list ed1))
                               (if (= "1" tg3)
                                   (cons (list ed3 ed4) (mapcar '(lambda ( x ) (list (car x) (itoa (cdr x)))) lst))
                                   (cons (list ed3)     (mapcar '(lambda ( x ) (list (car x))) lst))
                           fnm
                       (princ (strcat "\\nBlock data written to " fnm))
                       (count:popup "Unable to Create Output File" 48
                           (princ
                               (strcat
                                   "The program was unable to create the following file:\\n\\n"
                                   fnm
                                   "\\n\\nPlease ensure that you have write-permissions for the above directory."
   (*error* nil)
   (princ)
(defun c:blkcountsettings
       *error*
       dch des
       ord out out-fun
       srt
       tg1 tg1-fun tg2 tg2-fun tg3 tg3-fun
           (close des)
       (if (and (= 'int (type dch))
                (< 0 dch)
           (unload_dialog dch)
           (progn
       (princ)
   (cond
       (   (not (count:writedcl count:dclfname))
           (count:popup "DCL file could not be written" 48
               (princ
                   (strcat
                       "The DCL file required by this program could not be written to the following location:\\n\\n"
                       count:dclfname
       (   (<= (setq dch (load_dialog count:dclfname)) 0)
           (count:popup "DCL file could not be loaded" 48
               (princ
                   (strcat
                       "The following DCL file required by this program could not be loaded:\\n\\n"
                       count:dclfname
                       "\\n\\nPlease verify the integrity of this file."
       (   (not (new_dialog "dia" dch))
           (count:popup "DCL file contains an error" 48
               (princ
                   (strcat
                       "The program dialog could not be displayed as the following DCL file file contains an error:\\n\\n"
                       count:dclfname
       (   t
           (set_tile "dcl"
               (strcat
                   "Count.lsp Version "
                   (vl-string-translate "-" "." count:version)
                   " \\\\U+00A9 Lee Mac "
                   (menucmd "m=\\\$(edtime,0,yyyy)")
               (progn
                   (mode_tile "tab" 1)
                   (setq out "txt")
           (   (setq tg1-fun (lambda ( val ) (mode_tile "ed1" (- 1 (atoi (setq tg1 val)))))) (set_tile "tg1" tg1))
           (action_tile "tg1" "(tg1-fun \\\$value)")
           (   (setq tg2-fun (lambda ( val ) (mode_tile "ed2" (- 1 (atoi (setq tg2 val)))))) (set_tile "tg2" tg2))
           (action_tile "tg2" "(tg2-fun \\\$value)")
           (   (setq tg3-fun (lambda ( val ) (mode_tile "ed4" (- 1 (atoi (setq tg3 val)))))) (set_tile "tg3" tg3))
           (action_tile "tg3" "(tg3-fun \\\$value)")
           (foreach key '("ed1" "ed2" "ed3" "ed4")
               (set_tile key (eval (read key)))
               (action_tile key (strcat "(setq " key " \\\$value)"))
           (set_tile out "1")
           (   (setq out-fun
                   (lambda ( val )
                       (if (= "tab" (setq out val))
                           (progn
                               (mode_tile "tg2" 0)
                               (mode_tile "ed2" (- 1 (atoi tg2)))
                           (progn
                               (mode_tile "tg2" 1)
                               (mode_tile "ed2" 1)
               out
           (foreach key '("tab" "txt" "csv" "com")
               (action_tile key "(out-fun \\\$key)")
           (set_tile srt "1")
           (foreach key '("blk" "qty")
               (action_tile key "(setq srt \\\$key)")
           (set_tile ord "1")
           (foreach key '("asc" "des")
               (action_tile key "(setq ord \\\$key)")
           (if (= 1 (start_dialog))
               (count:writecfg count:cfgfname (mapcar 'eval (mapcar 'car count:defaults)))
   (*error* nil)
   (princ)
(defun count:popup ( ttl flg msg / err )
   (setq err (vl-catch-all-apply 'vlax-invoke-method (list (count:wsh) 'popup msg 0 ttl flg)))
   (if (null (vl-catch-all-error-p err))
       err
(defun count:wsh nil
   (cond (count:wshobject) ((setq count:wshobject (vlax-create-object "wscript.shell"))))
(defun count:tostring ( arg / dim )
   (cond
       (   (= 'int (type arg))
           (itoa arg)
       (   (= 'real (type arg))
           (setq dim (getvar 'dimzin))
           (setvar 'dimzin 8)
           (setq arg (rtos arg 2 15))
           (setvar 'dimzin dim)
           arg
       (   (vl-prin1-to-string arg))
(defun count:writecfg ( cfg lst / des )
   (if (setq des (open cfg "w"))
       (progn
           (foreach itm lst (write-line (count:tostring itm) des))
           (setq des (close des))
           t
(defun count:readcfg ( cfg lst / des itm )
   (if
       (and
           (setq cfg (findfile cfg))
           (setq des (open cfg "r"))
       (progn
           (foreach sym lst
               (if (setq itm (read-line des))
                   (set  sym (read itm))
           t
(defun count:writedcl ( dcl / des )
   (cond
       (   (findfile dcl))
       (   (setq des (open dcl "w"))
           (foreach itm
                   "//--------------------=={ Count Dialog Definition }==-------------------//"
                   "//  Dialog definition file for use in conjunction with Count.lsp        //"
                   "//  Author:  Lee Mac, Copyright © 2014  -  www.lee-mac.com              //"
                   "b15 : edit_box"
                   "    edit_width = 16;"
                   "    edit_limit = 1024;"
                   "    fixed_width = true;"
                   "    alignment = centered;"
                   "    horizontal_margin = none;"
                   "    vertical_margin = none;"
                   "b30 : edit_box"
                   "    edit_width = 52;"
                   "tog : toggle"
                   "    horizontal_margin = 0.2;"
                   "rwo : row"
                   "rrw : radio_row"
                   "dia : dialog"
                   "    key = \\"dcl\\";"
                   "    spacer_1;"
                   "    : boxed_column"
                   "        label = \\"Output\\";"
                   "        : rrw"
                   "            : radio_button { key = \\"tab\\"; label = \\"Table\\"; }"
                   "            : radio_button { key = \\"txt\\"; label = \\"Text File\\"; }"
                   "            : radio_button { key = \\"csv\\"; label = \\"CSV File\\"; }"
                   "            : radio_button { key = \\"com\\"; label = \\"Command line\\"; }"
                   "        spacer;"
                   "    : boxed_column"
                   "        label = \\"Headings\\";"
                   "        spacer_1;"
                   "        : rwo"
                   "            : tog { key = \\"tg1\\"; }"
                   "            : b30 { key = \\"ed1\\"; }"
                   "            : spacer"
                   "                width = 2.5;"
                   "        : rwo"
                   "            spacer;"
                   "            : tog { key = \\"tg2\\"; }"
                   "            : b15 { key = \\"ed2\\"; }"
                   "            : b15 { key = \\"ed3\\"; }"
                   "            : b15 { key = \\"ed4\\"; }"
                   "            : tog { key = \\"tg3\\"; }"
                   "            spacer;"
                   "        spacer_1;"
                   "    : row"
                   "        : boxed_column"
                   "            label = \\"Sort By\\";"
                   "            : rrw"
                   "                : radio_button { key = \\"blk\\"; label = \\"Block Name\\"; }"
                   "                : radio_button { key = \\"qty\\"; label = \\"Quantity\\"; }"
                   "            spacer;"
                   "        : boxed_column"
                   "            label = \\"Sort Order\\";"
                   "            : rrw"
                   "                : radio_button { key = \\"asc\\"; label = \\"Ascending\\"; }"
                   "                : radio_button { key = \\"des\\"; label = \\"Descending\\"; }"
                   "            spacer;"
                   "    spacer_1; ok_cancel;"
                   "//                             End of File                              //"
               (write-line itm des)
           (while (not (findfile dcl))) ;; for slow HDDs
           dcl
(defun count:writecsv ( lst csv / des sep )
   (if (setq des (open csv "w"))
       (progn
           (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\\\Control Panel\\\\International" "sList")) (",")))
           (foreach row lst (write-line (count:lst->csv row sep) des))
           (close des)
           t
(defun count:lst->csv ( lst sep )
   (if (cdr lst)
       (strcat (count:csv-addquotes (car lst) sep) sep (count:lst->csv (cdr lst) sep))
(defun count:csv-addquotes ( str sep / pos )
   (cond
       (   (wcmatch str (strcat "*[`" sep "\\"]*"))
           (setq pos 0)
           (while (setq pos (vl-string-position 34 str pos))
               (setq str (vl-string-subst "\\"\\"" "\\"" str pos)
                     pos (+ pos 2)
           (strcat "\\"" str "\\"")
       (   str   )
(defun count:writetxt ( lst txt / des )
   (if (setq des (open txt "w"))
       (progn
           (foreach itm lst (write-line (count:lst->str itm "\\t") des))
           (close des)
           t
(defun count:lst->str ( lst del )
   (if (cdr lst)
       (strcat (car lst) del (count:lst->str (cdr lst) del))
       (car lst)
(defun count:padbetween ( s1 s2 ch ln )
       (lambda ( a b c )
           (repeat (- ln (length b) (length c)) (setq c (cons a c)))
           (vl-list->string (append b c))
       (ascii ch)
       (vl-string->list s1)
       (vl-string->list s2)
(defun count:setblocktablerecord ( obj row col blk )
   (eval
       (list 'defun 'count:setblocktablerecord '( obj row col blk )
           (cons
               (if (vlax-method-applicable-p obj 'setblocktablerecordid32)
                   'vla-setblocktablerecordid32
               (list
                   'obj 'row 'col
                   (list 'count:objectid (list 'vla-item (vla-get-blocks (count:acdoc)) 'blk))
                   ':vlax-true
   (count:setblocktablerecord obj row col blk)
(defun count:objectid ( obj )
   (eval
       (list 'defun 'count:objectid '( obj )
           (cond
               (   (not (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*"))
                  '(vla-get-objectid obj)
               (   (= 'subr (type vla-get-objectid32))
                  '(vla-get-objectid32 obj)
               (   (list 'vla-getobjectidstring (vla-get-utility (count:acdoc)) 'obj ':vlax-false))
   (count:objectid obj)
(defun count:assoc++ ( key lst / itm )
   (if (setq itm (assoc key lst))
       (subst (cons key (1+ (cdr itm))) itm lst)
       (cons  (cons key 1) lst)
(defun count:effectivename ( ent / blk rep )
   (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
       (if
           (and
               (setq rep
                   (cdadr
                       (assoc -3
                           (entget
                               (cdr
                                   (assoc 330
                                       (entget
                                           (tblobjname "block" blk)
                              '("AcDbBlockRepBTag")
               (setq rep (handent (cdr (assoc 1005 rep))))
           (setq blk (cdr (assoc 2 (entget rep))))
   blk
(defun count:startundo ( doc )
   (count:endundo doc)
   (vla-startundomark doc)
(defun count:endundo ( doc )
   (while (= 8 (logand 8 (getvar 'undoctl)))
       (vla-endundomark doc)
(defun count:acdoc nil
   (eval (list 'defun 'count:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (count:acdoc)
(vl-load-com)
(princ
   (strcat
       "\\n:: Count.lsp | Version "
       " | \\\\U+00A9 Lee Mac "
       " www.lee-mac.com ::"
       "\\n:: \\"blkcount\\" - Main Program | \\"blkcountsettings\\" - Settings ::"
(princ)
;;                             End of File                              ;;
