3D arcs from command line
Hello everyone !
I mainly use 3D coordinates to draw lines arcs. At one moment, I noticed that some of the commands, "arc" for instance, can do errors... or at least, it does not give what was expected.
Via the typed command "arc", I set the 3 points, with the following script:
arc
1.3457,0.0184,0.05
1.3107,-0.3092,0.
1.1955,-0.618,-0.05
Logically, the extremities of the arcs should be located at 1.3457,0.0184,0.05 and 1.1955,-0.618,-0.05, but there are not. (error is mostly along Z axis). Note that it works perfectly with lines, and points.
Am I correct ? Is there a problem here ?
With the mouse, I can produce the correct arc, by re-ajusting the Z coordinate and changing view. The attached dwg allows seeing the problem the green arc is expected, and the white one is false...
