I would like to spot different diameter holes in one operation. Because most carbide drills do not need a spotting operation before it is drilled, Still need to chamfer the hole before it is tapped. I can only spot by depth or diameter. Need to be able to spot different diameters in the same pattern then add chamfer depth depending on diameter of hole.
