When you load in your PPR a NC machine the default position is 0,0,0,0,0 (as created in Equipment and Design).
Is it possible to load it with others values , to impose ‘home position’ ? exemple : 0,0,550,0,0 (change the Z)
Is It possible to impose different position in many workcell ?
You can use a machine instruction at the beginning of the manufacturing program, but it is “boring” and the default display to load the setup is not nice
You can recreate the machine with the expected loaded position, but the XYZ values in the datareadout are not very nice !
Is there another method ?
