First, I am on the maker version, in case that has any bearing on the issue.
I have one tool that seems to post a bad syntax to APT and cannot figure out why. All other tools seem to be fine. Here's a snip of the tool in APT:
\\\$\\\$ TOOLCHANGEBEGINNING
RAPID
GOTO / 170.00000, 160.00000, 120.00000
CUTTER/ 6.000000, 0.000000, 3.000000, 0.000000, 0.000000,\\\$
0.000000, 13.000000
\\\$\\\$ Select sequence 1 to exclude tool compensation
APPLY/MILL
OPTYPE/TOOL
TLNAME/'6 x 13 x 57 0R EM
#1005:2/TOOL,LENGTH, 57.000000
#1005:19/TOOL,LENGTH, 57.000000
#1005:19/HOLDER,LENGTH, 57.000000--
LOAD/TOOL,1
COOLNT/
\\\$\\\$ TOOLCHANGEEND As you can see the underlined record has trailing hyphens, which is causing errors when trying to debug the post in Gener. Admittedly, I am on the bottom of the rather steep learning curve here, so if there are other resources I could be pointed to, I am not averse to study.
Many thanks.
