ABB NRL Output Question
I test the Mill for ABB Robot function then I have some Question:
1. PERS tooldata [name] : How I control the name value ?
I modify the tool's title name, instance name, but can't output what i want value.
2. Warning: No template directory set. Match of robot in 3DExp and Rapid robot base will not be possible.
How I can set the template directory ?
3. Warning: Either no MOC.cfg file found or no valid match could be checked between 3DExp robot and Rapid robot base location. No adjustment of wobjdata/objectframe profiles will be done.
How can I do ??
or Someone can shall the meterial for the Generating NC Code by Robot ??
Thank you very much!!
