Hi everyone,
I wrote a macro with catia and when I press the button I want it to transfer the value in my variable named dim code1 as string to the part number value of the active document is PART DOCUMENT part.
Dim activedoc as object
Set activedoc = catia.activedocument
Dim code1 as string
Code1 = "A123456"
If typeof activedoc is pardocument then
Dim prt as part
Set prt= activedoc.prt
'Here not working
'prt.name=code1
'prt.Part.partnumber=code1
'Prt.part.name=code1
Else
Others code...
End if
Why doesn't the above code block write the data of my variable to the partnumber section if it is the active document part?
