for a customer I've created a titleblock as usual in detailsheet with table and rename the feature to "TitleBlock_xxx"
it works well for the linked attributes from 3D model and drawing and with the smal workaround also for assigned core material.
The challange is to implement a funcktion like exist in DS "Drawing_Titleblock_Sample1.CATScript" to add checked by and approved by also if the 3D model and drawing is in maturity state of released.
up to now I have no chance to modify the drawing titleblock if it is released or the Change Action is in state "inApproval". In both cases a modification is blocked and the drawing is not updated.
Sure, with "owner" role I'm able to modify the attribute values in drawing properties, but there is no solution to update title block if drawing is released.
I want to know, if there is a service of Dassault Systems to prepare a customized CATScript based in customers requirement. How is the responsible contact person in it?
Thank you
Thomas Degen (TECHNIA)
