Edge Fillet with Different Values on Side A and Side B
Hi Team,
I would like to create an Edge Fillet on the selected edge as shown in the attached image. However, my requirement is to have different fillet values on each side of the edge:
  • Side A: 1 mm
  • Side B: 10 mm
Could you please confirm whether this is possible in CATIA V5? If yes, could you kindly guide me on the recommended approach or the steps required to achieve this?
Thank you in advance for your support.
Best Regards,
 Anup C K
Answers 2
HE
HE 2026-10-25
hi @AA not quite sure what you are trying to do, with different radii you can't  have an intersection point to create the fillet. what is this product and what is the underlying requirement.
SS
SS 2026-10-26
Hi @AA , There is not that capability to do this in catia or even other cad software as like as you want , and the cause of this is computational problem that may occurs, I mean  when you want two arc in a fillet that geometry can produce in many way , and because of that we have not single tool for doing that , you may create by yourself manually based on parameters you have.
look at this example and images below, all of them have same dimension that you have mentioned with out any problem !! so which one could be your answer when catia wants to compute?
comment imagecomment imagecomment imagecomment imagecomment imagecomment image
