Hello everyone,
I'm currently working on a custom Drafting Template in CATIA V5 (or the 3DEXPERIENCE platform equivalent) and I am facing a persistent issue with the automatic indexation of the Revision Table and the Title Block.
I understand that for these elements to be properly indexed and managed by the drawing tools, they must be named using specific prefixes in the Sheet Background view.
📌 My Setup and Attempted Fixes:
- Objective: Create a working template where the Revision Management tools are active.
- Required Prefixes:
- For the Revision Table:
RevisionTable_ - For the Title Block (Cartouche):
TitleBlock_
- My Current Situation (Problem): The system does not recognize these objects, and the revision tools remain inactive, despite the correct naming convention.
- Key Observation (As seen in my tree):
- I have ensured that I rename the objects in the Sheet Background mode, not just an instance in a Drawing View.
- My elements are currently named (e.g.,
RevisionTable_CustomNameandTitleBlock_A3_Vertical). - The Revision Table was created using the dedicated Revision Table tool, not manually with lines and text.
I am attaching a screenshot of my tree structure within the Sheet Background to show the current naming.
Thank you in advance for your help!
