"Create Import" command, "Create context" behavior
I found that the possibility to deselect of the "Create Context" checkbox depends on how the "Create Import" command is started.
If one or more objects are selected before running "Create Import", the "Create Context" checkbox cannot be deselected (it is active but disabled). However, if I start "Create Import" first and then select the objects to import, the checkbox can be deselected.
I would like to understand why this behavior exists and whether there is a setting that can change it. I prefer selecting the objects first and then running the command, rather than the other way around.
If this behavior is working as designed, could you explain the reasoning behind it so I can better understand how the command is intended to be used?
Thanks in advance.
