I have design a aluminium boat sheets in Generative Shape Design using splines->Intersections>sweeps.
After this I unfold the sweep sheets by using DL1 Developed shapes.
Then I add a plane using 3-point to get is flat in the drawing screen.
When I make a drawing of this everything looks fine.
But when I save it to dxf with only contours it does not work in the CAM program of the water cutting machine. (Conrours has interuptions, lines in different layers)
When I look at it in the drawing it all look good without any interuptions or lines in different layers.
If I print this it all looks great.
Any idea how to solve this issue??
Best Regards
Richard
Hi! What is likely happening the Developed Shape (DL1) is generated from:
Spline → Intersection → Sweep → Developed Shape → Drawing → DXF
Each conversion may introduce approximations. When the DXF is exported, CATIA often converts the geometry into: LINE, ARC, POLYLINE or worse SPLINE fragmented into hundreds of segments...
Solution (not guaranteed), open the DXF in AutoCAD or DraftSight. PEDIT / JOIN to join the entities.
Hope it's useful...
